Salta al contenuto principale
Apple AirPort Extreme Model A1034 Antenna Replacement
Cosa ti serve
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 2, immagine 1 di 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 3, immagine 1 di 2 Apple AirPort Extreme Model A1034 Antenna Replacement: passo 3, immagine 2 di 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 4, immagine 1 di 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: passo 5, immagine 1 di 1
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 6, immagine 1 di 1
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Conclusione
Cal Poly, Team 17-15, Regan Fall 2011 Membro di Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,668
