Introduzione
How to open the converter box and replace the power supply...
Unplug your device from the wall outlet.
  • Unplug your device from the wall outlet.
Aggiungi Commento
Remove the screws on the sides and rear. There are two on each side and four on the back.
  • Remove the screws on the sides and rear. There are two on each side and four on the back.
  • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
Aggiungi Commento
Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
Aggiungi Commento
Locate the power board inside the converter box.
  • Locate the power board inside the converter box.
  • Circled in red in the picture.
Aggiungi Commento
Remove this plug
  • Remove this plug
  • You will need to squeeze the locking lever to release it. don't pull too hard.
Aggiungi Commento
Remove this plug from the main board. It is not detachable from the power board end.
  • Remove this plug from the main board. It is not detachable from the power board end.
  • Be gentle.
Aggiungi Commento
Remove one last cable. This one leads to the front panel
  • Remove one last cable. This one leads to the front panel
  • Be gentle.
  • Circled in red
Aggiungi Commento
Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
  • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
  • Circled in blue
Aggiungi Commento
Remove the four silver colored philips screws holding the power board in.
  • Remove the four silver colored philips screws holding the power board in.
  • Marked in pink (eeww)
Aggiungi Commento
Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
  • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
  • Here is the empty spot.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Michel
Membro da: 18/06/2010
261 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 8,489
