Parti
Nessuna parte richiesta.
Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
  • Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
Aggiungi Commento
Remove the 4 screws to continue.
  • Remove the 4 screws to continue.
Aggiungi Commento
Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
Aggiungi Commento
Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
Aggiungi Commento
Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
  • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
Aggiungi Commento
Gently remove board.
  • Gently remove board.
Aggiungi Commento
The side buttons are the red push buttons highlighted in red. To remove them, flip the board over and desolder the leads highlighted in orange. Replace components with new ones and resolder back in place.
  • The side buttons are the red push buttons highlighted in red.
  • To remove them, flip the board over and desolder the leads highlighted in orange.
  • Replace components with new ones and resolder back in place.
Aggiungi Commento
Conclusione
Andreas Apitz
Membro da: 23/01/2014
116 Reputazione
1 Guida realizzata
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 343
