Salta al contenuto principale
Anker 2.4G Wireless Mouse Sensor Replacement
Cosa ti serve
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: passo 1, immagine 1 di 1
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: passo 2, immagine 1 di 1
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: passo 3, immagine 1 di 2 Anker 2.4G Wireless Mouse Sensor Replacement: passo 3, immagine 2 di 2
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: passo 4, immagine 1 di 1
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: passo 5, immagine 1 di 1
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  7. Anker 2.4G Wireless Mouse Sensor Replacement: passo 7, immagine 1 di 1
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan
Membro da: 01/23/14
140 Reputazione
1 Guida realizzata
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 7,499
