Introduzione
Here's how to take your mouse apart, and how to get the buttons working again.
Use the screwdriver to peal off the stickers marked with red rectangles in the provided image. This will reveal the location of 4 screws.
  • Use the screwdriver to peal off the stickers marked with red rectangles in the provided image. This will reveal the location of 4 screws.
Aggiungi Commento
Remove the 4 revealed screws marked with red in the provided image.
  • Remove the 4 revealed screws marked with red in the provided image.
Aggiungi Commento
Use a flat head screw driver to pry apart the upper and lower housing of the mouse. Use a flat head screw driver to pry apart the upper and lower housing of the mouse.
  • Use a flat head screw driver to pry apart the upper and lower housing of the mouse.
Aggiungi Commento
Pull the wires from the white crimping headers to disconnect them, separating the top from bottom.
  • Pull the wires from the white crimping headers to disconnect them, separating the top from bottom.
  • Pull as far up on the wire as possible, but avoid ripping the wires by applying too much force.
Aggiungi Commento
Scroll wheel between left and right buttons
  • Scroll wheel between left and right buttons
    • Remove the scroll wheel from the mother board by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
Aggiungi Commento
Pull the mother board gently away from the plastic housing.
  • Pull the mother board gently away from the plastic housing.
Aggiungi Commento
Desolder the components and re-solder the replacements in order to repair the left and right buttons. Desolder the components and re-solder the replacements in order to repair the left and right buttons.
  • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Vincent Lee
Membro da: 23/01/2014
361 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
8 Guide realizzate
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,892
