Use screwdriver to gently pry off the stickers marked in red to reveal the location of the 4 screws
  • Use screwdriver to gently pry off the stickers marked in red to reveal the location of the 4 screws
Aggiungi Commento
Remove the 4 screws to continue.
  • Remove the 4 screws to continue.
Aggiungi Commento
Pry the center of the mouse apart to separate upper and lower housing of the boards. Pry the center of the mouse apart to separate upper and lower housing of the boards.
  • Pry the center of the mouse apart to separate upper and lower housing of the boards.
Aggiungi Commento
Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
Aggiungi Commento
Take the upper housing of the mouse and remove the two screws (highlighted in red) that hold the board in place. Take the upper housing of the mouse and remove the two screws (highlighted in red) that hold the board in place.
  • Take the upper housing of the mouse and remove the two screws (highlighted in red) that hold the board in place.
Aggiungi Commento
Gently remove board.
  • Gently remove board.
Aggiungi Commento
The LED is the red component on this board circled in red. To remove it, flip the board over and desolder the wired highlighted in orange.
  • The LED is the red component on this board circled in red.
  • To remove it, flip the board over and desolder the wired highlighted in orange.
  • Replace LED with a new LED and resolder into place.
Aggiungi Commento
Conclusione
Colin
Membro da: 10/02/2014
313 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,244
