Salta al contenuto principale
Amazon Echo Show 2nd Gen Sound foam Replacement
Cosa ti serve
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: passo 1, immagine 1 di 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: passo 1, immagine 2 di 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: passo 1, immagine 3 di 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: passo 2, immagine 1 di 3 Amazon Echo Show 2nd Gen Sound foam Replacement: passo 2, immagine 2 di 3 Amazon Echo Show 2nd Gen Sound foam Replacement: passo 2, immagine 3 di 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,589
