Introduzione
This guide will show you how to safely access and replace the hard drive for the Alienware M14xR2 laptop. Before replacing the hard drive you will need to remove the battery and the CD drive.
Turn the computer off.
  • Turn the computer off.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the charging cable could result in electric shock and serious injury.
  • Flip the computer upside down.
Aggiungi Commento
Loosen the two 6.35 mm size 1 Phillips screws on the back cover. The two screws are spring loaded and will not separate from the cover. Slide the back cover towards you and then  lift upwards to remove.
  • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
  • Slide the back cover towards you and then lift upwards to remove.
Aggiungi Commento
Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
  • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
  • The two screws are clipped into the battery and will not detach.
Aggiungi Commento
Pull up on the black tab on the battery to reveal the connection between the battery and laptop. Pull up on the white connector to disconnect it from the laptop. The battery is now free to remove from the laptop and can be set aside.
  • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
  • Pull up on the white connector to disconnect it from the laptop.
  • The battery is now free to remove from the laptop and can be set aside.
Aggiungi Commento
Unscrew the four 6.35 mm size 1 screws. Pull up on the end of the orange tab to detach it from the white connector. Lift the optical drive up and out of the laptop and set it aside.
  • Unscrew the four 6.35 mm size 1 screws.
  • Pull up on the end of the orange tab to detach it from the white connector.
  • Lift the optical drive up and out of the laptop and set it aside.
Aggiungi Commento
Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop. The screws are spring loaded and will not come loose from the hard drive assembly.
  • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
  • The screws are spring loaded and will not come loose from the hard drive assembly.
  • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
Aggiungi Commento
Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it. Set aside the now disconnected hard drive.
  • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
  • Set aside the now disconnected hard drive.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Connor Bovee
Membro da: 30/09/2013
510 Reputazione
2 Guide realizzate
Cal Poly, Team 13-4, Forte Fall 2013 Membro di Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 109
Tutti i Tempi: 8,603
