Introduzione
The trigger is the starting mechanism to shoot the darts from your blaster. You must be careful not to harm other parts of the blaster while taking out the trigger.
Parti
Nessuna parte richiesta.
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
  • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
  • Remove grey slider from the main body of the blaster.
Aggiungi Commento
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Aggiungi Commento
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Aggiungi Commento
Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger. Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger. Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
  • Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
Aggiungi Commento
Conclusione
USF Tampa, Team 3-1, Brown Fall 2014 Membro di USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 130
