Introduzione
This guide will show the procedure for removing each segment of the pump rod. It can be used to replace the entire rod, or just to replace a single pump rod segment.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Assemble the required tools, including the Afridev tool and crescent wrenches. Assemble the required tools, including the Afridev tool and crescent wrenches.
  • Assemble the required tools, including the Afridev tool and crescent wrenches.
Aggiungi Commento
Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters. Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters. Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
Aggiungi Commento
Loosen the bolt on front of the face plate with the Afridev tool. Remove the plate from the pump by lifting it straight up.
  • Loosen the bolt on front of the face plate with the Afridev tool.
  • Remove the plate from the pump by lifting it straight up.
Aggiungi Commento
Insert the T-handle into the top cylinder of the exposed pump rod. Insert the T-handle into the top cylinder of the exposed pump rod. Insert the T-handle into the top cylinder of the exposed pump rod.
  • Insert the T-handle into the top cylinder of the exposed pump rod.
Aggiungi Commento
Loosen the 2 bolts on either side of handle. It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  • Loosen the 2 bolts on either side of handle.
  • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
Aggiungi Commento
Loosen the 2 bolts on either side of the head to remove the handle from the pump rod. It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle. It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
Aggiungi Commento
Lift the handle to a horizontal position. Lift the handle to a horizontal position.
  • Lift the handle to a horizontal position.
Aggiungi Commento
While one person lifts up on the T-handle, remove the bolt and connection pieces. While one person lifts up on the T-handle, remove the bolt and connection pieces. While one person lifts up on the T-handle, remove the bolt and connection pieces.
  • While one person lifts up on the T-handle, remove the bolt and connection pieces.
Aggiungi Commento
Remove the bolt and connection pieces from the handle. Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination. Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  • Remove the bolt and connection pieces from the handle.
  • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
Aggiungi Commento
Remove the handle from the pump. Be sure to set the handle in a sanitary place to prevent contamination.
  • Remove the handle from the pump.
  • Be sure to set the handle in a sanitary place to prevent contamination.
Aggiungi Commento
Grab firmly on the T-handle and lift the pump rod straight up. Expose the first connection of the pump rod, and support the portion below the connection.
  • Grab firmly on the T-handle and lift the pump rod straight up.
  • Expose the first connection of the pump rod, and support the portion below the connection.
Aggiungi Commento
While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position. While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
Aggiungi Commento
Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod. Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod. Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
Aggiungi Commento
Repeat steps 11-13 for the remaining sections of pump rod. Be sure to set the pump rod segments above the ground to avoid contamination. Be sure to set the pump rod segments above the ground to avoid contamination.
  • Repeat steps 11-13 for the remaining sections of pump rod.
  • Be sure to set the pump rod segments above the ground to avoid contamination.
Aggiungi Commento
Conclusione
Jake Devincenzi
Membro da: 18/04/2011
104.240 Reputazione
108 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 182
