Salta al contenuto principale
Adjusting Right/Left Speaker Balance
  1. Adjusting Right/Left Speaker Balance, Adjusting Right/Left Speaker Balance: passo 1, immagine 1 di 1
    • The balance knob is the rightmost knob on the front panel.
  2. Adjusting Right/Left Speaker Balance: passo 2, immagine 1 di 2 Adjusting Right/Left Speaker Balance: passo 2, immagine 2 di 2
    • Turning the balance knob to the right increases the sound played by the right speaker.
    • Turning the knob left will increase the sound played by the left speaker.
  3. Adjusting Right/Left Speaker Balance: passo 3, immagine 1 di 2 Adjusting Right/Left Speaker Balance: passo 3, immagine 2 di 2
    • Turning the knob all the way to the right will make the right speaker play all the sound.
    • Turning the knob all the way to the left will make the left speaker play all the sound.
  4. Adjusting Right/Left Speaker Balance: passo 4, immagine 1 di 1
    • The default position is center, which should play the sound equally by both speakers.
    • If this position does not play the sound equally by both speakers, experiment with different knob positions until the speakers play the sound equally.
Linea Traguardo
Jan Vazquez
Membro da: 04/09/10
239 Reputazione
1 Guida realizzata
Cal Poly, Team 27-92, Amido Spring 2010 Membro di Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Membri
7 Guide realizzate
Un commento
Finally, I can die in peace
john goor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,701
