Introduzione
The front and rear derailleurs (pronounced "derailer" but spelled this way because of the French) are what move the bike's chain back and forth across your gear sets, allowing you to shift between different gear combinations and thus handle a variety of speeds and inclines.
However, in order for the derailleur to work properly, it needs to be adjusted so that it's shifting over the correct range. That's what this guide will show you how to do.
Parti
Nessuna parte richiesta.
Shift the bike's rear derailleur onto the innermost gear.
  • Shift the bike's rear derailleur onto the innermost gear.
Aggiungi Commento
Shift the front derailleur as far inward as it can go.
  • Shift the front derailleur as far inward as it can go.
    • If the chain falls off, tighten the outside limit screw on top of the derailleur.
    • If the chain can't shift to the lower gear, loosen the outside limit screw on top of the derailleur.
  • Yes, the outer limit screw adjusts the inner derailleur limit.
Aggiungi Commento
Next, shift the rear derailleur onto the outermost gear.
  • Next, shift the rear derailleur onto the outermost gear.
Aggiungi Commento
Shift the front derailleur as far outwards as you can.
  • Shift the front derailleur as far outwards as you can.
    • If the derailleur shifts the chain off the gear, tighten the inner limit screw on top of the front derailleur.
    • If the derailleur is unable to shift onto the outer gear, loosen the inner limit screw on top of the front derailleur.
  • Just like last time, the inner limit screw adjusts the outer limit of the derailleur.
Aggiungi Commento
Conclusione
Now, your bike shouldn't have any more problems with the chain falling off.
Tobias Elder
Membro da: 25/04/2013
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 961
