Salta al contenuto principale
Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet
  1. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet, Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: passo 1, immagine 1 di 1
    • Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Detach the water reservoir from the brewer by lifting the reservoir vertically from the device.
  2. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: passo 2, immagine 1 di 2 Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: passo 2, immagine 2 di 2
    • The magnet is located in the bottom of the reservoir.
    • Remove the grey lid from the top of the reservoir.
    • Insert your hand and manually realign the magnet to where it slides freely in its enclosed area.
Conclusione
Altre 2 persone hanno completato questa guida.
Alexander Vo
Membro da: 01/11/13
94 Reputazione
2 Guide realizzate
Cal Poly, Team 20-2, Maness Winter 2013 Membro di Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 70
Tutti i Tempi: 19,842
