Introduzione
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
Parti
Nessuna parte richiesta.
Remove the bolt cover with a flathead screwdriver. Remove the bolt cover with a flathead screwdriver.
  • Remove the bolt cover with a flathead screwdriver.
Aggiungi Commento
Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
  • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
  • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
  • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
  • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
  • Make sure you don't raise quill stem above minimum insert line.
Aggiungi Commento
Align the direction of the goose-neck (adjustable quill stem) with the front tire. Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench. Pop the bolt cover back on.
  • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
  • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
  • Pop the bolt cover back on.
  • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Aggiungi Commento
Linea Traguardo
aaron thielk
Membro da: 10/10/2010
1.672 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
11 Guide realizzate
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 43
Tutti i Tempi: 7,509
