Introduzione
The motherboard holds important electronic components and directs signals from the computer to the monitor screen.
Place the monitor screen face down. Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
  • Place the monitor screen face down.
  • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
  • Pull the stand away from the monitor.
Aggiungi Commento
Use the plastic opening tool to pry the back panel from the front panel. Start at one point of the crease and pry along the edge of the entire monitor for the best results. Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  • Use the plastic opening tool to pry the back panel from the front panel.
  • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
Aggiungi Commento
Gently lift back panel away from the monitor.
  • Gently lift back panel away from the monitor.
Aggiungi Commento
Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot. Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
  • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
Aggiungi Commento
Remove the four 10 mm hex screws. Remove the four 10 mm hex screws.
  • Remove the four 10 mm hex screws.
Aggiungi Commento
Gently lift the motherboard casing from the monitor.
  • Gently lift the motherboard casing from the monitor.
Aggiungi Commento
The following steps give instructions for detaching the three connectors shown in the picture.
  • The following steps give instructions for detaching the three connectors shown in the picture.
Aggiungi Commento
Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
  • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
  • The connector will be released from the motherboard immediately.
Aggiungi Commento
Lift the black seal to release the large ribbon connector (the ZIF connector).
  • Lift the black seal to release the large ribbon connector (the ZIF connector).
Aggiungi Commento
Pull the bundled cable connector gently away from motherboard.
  • Pull the bundled cable connector gently away from motherboard.
Aggiungi Commento
Gently lift the motherboard to remove  it from the monitor.
  • Gently lift the motherboard to remove it from the monitor.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Jeffrey Kong
Membro da: 22/09/2014
707 Reputazione
5 Guide realizzate
Cal Poly, Team 12-3, Forte Fall 2014 Membro di Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Membri
5 Guide realizzate
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 66
Tutti i Tempi: 2,592
