Introduzione
If it says "Too many pattern attempts..." or not working Android system, or you want to erase all data.
__________Video tutorial:__________
Panoramica Video
From the reset hole we can make reset without erasing data. From the reset hole we can make reset without erasing data. From the reset hole we can make reset without erasing data.
  • From the reset hole we can make reset without erasing data.
Aggiungi Commento
Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time. Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time. Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
Aggiungi Commento
Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key. Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
  • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
  • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
Hi when i make it, fastboot mode was in the screen
Sihem Smiti - Replica
Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now". Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now". Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
Aggiungi Commento
After restart you will have empty (free of data) device and access to it. . Please SUBSCRIBE to my channel  ツ
buen dia la tablet se queda en la pantalla de welcome que hago
Frank Rondon - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
153.670 Reputazione
431 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
725 Guide realizzate
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - Replica
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 212
Tutti i Tempi: 66,319
