Introduzione
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
Panoramica Video
Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
  • Switch-off the tablet.
  • If you have a memory card inside, don't forget to remove it!
  • Use a cutter and a plastic tool to remove the back cover.
Aggiungi Commento
Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  • Disconnect the battery connector.
  • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
Aggiungi Commento
Li-on Batteri Pack, 3.8V, 2640mAh
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
153.600 Reputazione
431 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
725 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 53
Ultimi 30 Giorni: 281
Tutti i Tempi: 16,432
