Introduzione
This guide will lead you step-by-step through how to remove the Iconia A110 battery.
Parti
Nessuna parte richiesta.
Before taking apart your tablet, make sure the device is powered off. Pry open the right side of case with the plastic opening tool.  If necessary, keep a tool lodged into the side to keep the case from closing.
  • Before taking apart your tablet, make sure the device is powered off.
  • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
  • During this process, the volume button and/or power button may fall out.
Aggiungi Commento
Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front. Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front. Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front.
  • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
Aggiungi Commento
Using the plastic opening tool and spudger, carefully pry up the battery from the case. You should hear the adhesive ripping as you do this. Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
  • You should hear the adhesive ripping as you do this.
  • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Andrea
Membro da: 14/04/2014
750 Reputazione
5 Guide realizzate
Cal Poly, Team 3-42, Maness Spring 2014 Membro di Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Membri
5 Guide realizzate
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 104
Tutti i Tempi: 10,071
