Salta al contenuto principale
Acer Chromebook C720 Solid State Drive (SSD) Replacement
Cosa ti serve
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, immagine 1 di 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, immagine 2 di 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, immagine 3 di 3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, immagine 1 di 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, immagine 2 di 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, immagine 3 di 3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 3, immagine 1 di 2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 3, immagine 2 di 2
    • Gently remove the SSD from the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
IUPUI, Team S2-G5, Harley Spring 2019 Membro di IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Membri
7 Guide realizzate
2 Commenti
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Replica
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 161
Tutti i Tempi: 5,532
