Salta al contenuto principale
Acer Chromebook 14 CB3-431-C7EX Battery Replacement
Cosa ti serve
  1. Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: passo 1, immagine 1 di 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: passo 1, immagine 2 di 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 2, immagine 1 di 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 2, immagine 2 di 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 2, immagine 3 di 3
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: passo 4, immagine 1 di 1
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
clear and concise
good instructions
battery can be found for less than half that cost online
mapatouli - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,759
