Salta al contenuto principale
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
Cosa ti serve
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 2, immagine 1 di 1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 3, immagine 1 di 1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 4, immagine 1 di 1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 5, immagine 1 di 2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,384
