Introduzione
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Please SUBSCRIBE to my channel ツ
Panoramica Video
Switch-off the Laptop. Remove 17x Philips screws.
  • Switch-off the Laptop.
  • Remove 17x Philips screws.
Aggiungi Commento
Start opening from the SD Memory Card hole Use plastic tools to avoid damaging the cover. Use plastic tools to avoid damaging the cover.
  • Start opening from the SD Memory Card hole
  • Use plastic tools to avoid damaging the cover.
Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
razbojnikkuro - Replica
Before doing anything, disconnect the battery.
Aggiungi Commento
This model have 1x Memory Slot. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600. .
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
152.890 Reputazione
430 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
723 Guide realizzate
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 198
Tutti i Tempi: 12,236
