Salta al contenuto principale
Acer Aspire V5-571 Optical Drive Replacement
Cosa ti serve
Panoramica Video
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, immagine 1 di 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, immagine 2 di 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, immagine 3 di 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: passo 2, immagine 1 di 3 Acer Aspire V5-571 Optical Drive Replacement: passo 2, immagine 2 di 3 Acer Aspire V5-571 Optical Drive Replacement: passo 2, immagine 3 di 3
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
2 Commenti
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Replica
Is it safe to use the laptop with the optical drive out?
Vianca - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,131
