Introduzione
USB is essential on modern laptops. Use this guide to fix your broken ports.
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Aggiungi Commento
Use a spudger to pry the panel up from the laptop case and remove it. The laptop should now be open with the RAM and wifi chip now accessible.
  • Use a spudger to pry the panel up from the laptop case and remove it.
  • The laptop should now be open with the RAM and wifi chip now accessible.
Aggiungi Commento
Locate the wifi chip.
  • Locate the wifi chip.
Aggiungi Commento
Remove the 5 mm Phillips #1 screw holding the wifi chip in place. Carefully remove the wifi chip.
  • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
  • Carefully remove the wifi chip.
Aggiungi Commento
Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
Aggiungi Commento
Flip the computer over, and with a spudger, remove the black panel directly below the keyboard. Remove the panel and flip it up onto the keyboard
  • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
  • Remove the panel and flip it up onto the keyboard
Aggiungi Commento
With the panel removed, locate the USB port ribbon cable connecting to the motherboard. Carefully disconnect the ribbon cable.
  • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
  • Carefully disconnect the ribbon cable.
Aggiungi Commento
Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
Aggiungi Commento
The USB ports can now be removed from the laptop.
  • The USB ports can now be removed from the laptop.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Ryan Holland
Membro da: 15/04/2014
362 Reputazione
2 Guide realizzate
Cal Poly, Team 8-8, Regan Spring 2014 Membro di Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,212
