Salta al contenuto principale
Acer Aspire V3-551-8887 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire V3-551-8887 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Motherboard Replacement: passo 2, immagine 1 di 2 Acer Aspire V3-551-8887 Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Motherboard Replacement, USB Ports: passo 3, immagine 1 di 1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Motherboard Replacement: passo 4, immagine 1 di 2 Acer Aspire V3-551-8887 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Motherboard Replacement: passo 6, immagine 1 di 2 Acer Aspire V3-551-8887 Motherboard Replacement: passo 6, immagine 2 di 2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Motherboard Replacement: passo 7, immagine 1 di 2 Acer Aspire V3-551-8887 Motherboard Replacement: passo 7, immagine 2 di 2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Motherboard Replacement: passo 8, immagine 1 di 1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Motherboard Replacement: passo 9, immagine 1 di 1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Motherboard Replacement, Keyboard: passo 10, immagine 1 di 1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Motherboard Replacement: passo 11, immagine 1 di 2 Acer Aspire V3-551-8887 Motherboard Replacement: passo 11, immagine 2 di 2
    • Use a spudger to gently lift the keyboard.
  12. Acer Aspire V3-551-8887 Motherboard Replacement, Motherboard: passo 12, immagine 1 di 1
    • Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
  13. Acer Aspire V3-551-8887 Motherboard Replacement: passo 13, immagine 1 di 1
    • Disconnect the 4 ribbon cables connected to the motherboard.
    • Some ribbon cable connections may not be accessible until after beginning to lift.
  14. Acer Aspire V3-551-8887 Motherboard Replacement: passo 14, immagine 1 di 1
    • Very carefully lift the motherboard.
    • Do not force the board. If stuck, check that the ports on the left are not stuck, that no wires are still attached, and no screws are still in.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 8-8, Regan Spring 2014 Membro di Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,292
