Salta al contenuto principale
Acer Aspire R7-572-6423 Battery Replacement
Cosa ti serve
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire R7-572-6423 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: passo 5, immagine 1 di 1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: passo 7, immagine 1 di 2 Acer Aspire R7-572-6423 Battery Replacement: passo 7, immagine 2 di 2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,505
