Introduzione
There is a battery lock and a latch holding the battery in place.
Strumenti
Nessun attrezzo richiesto.
Parti
Turn the netbook upside down with the battery at the top, away from you.
  • Turn the netbook upside down with the battery at the top, away from you.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
Aggiungi Commento
Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Doug Gallatin
Membro da: 05/10/2010
5.756 Reputazione
10 Guide realizzate
Cal Poly, Team 7-49, Amido Fall 2010 Membro di Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 45
Tutti i Tempi: 15,972
