Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
Aggiungi Commento
With a spudger, release the clips that hold the plastic frame to the back cover. Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
  • With a spudger, release the clips that hold the plastic frame to the back cover.
  • Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
Aggiungi Commento
When all the clips are out, the entire plastic frame should come out easily.
  • When all the clips are out, the entire plastic frame should come out easily.
Aggiungi Commento
Carefully disconnect the camera cable. Carefully disconnect the camera cable.
  • Carefully disconnect the camera cable.
Aggiungi Commento
Remove the 4 screws located in the sides of the LCD screen. Remove the 4 screws located in the sides of the LCD screen.
  • Remove the 4 screws located in the sides of the LCD screen.
Aggiungi Commento
Remove the other 4 screws that secure the metal LCD frame to the hinges.
  • Remove the other 4 screws that secure the metal LCD frame to the hinges.
Aggiungi Commento
Take the LCD screen out of the metal frame and flip it towards the keyboard. Take the LCD screen out of the metal frame and flip it towards the keyboard. Take the LCD screen out of the metal frame and flip it towards the keyboard.
  • Take the LCD screen out of the metal frame and flip it towards the keyboard.
Aggiungi Commento
Remove the tape that holds the display cable. Be careful not to take the entire tape away, as this may cause severe damage to the cable.
  • Remove the tape that holds the display cable.
  • Be careful not to take the entire tape away, as this may cause severe damage to the cable.
Aggiungi Commento
Carefully disconnect the cable with a spuger. Carefully disconnect the cable with a spuger.
  • Carefully disconnect the cable with a spuger.
Aggiungi Commento
Unstick the cables from the back of the LCD screen. The LCD should be completely free, so just take it out and install a new one.
  • Unstick the cables from the back of the LCD screen.
  • The LCD should be completely free, so just take it out and install a new one.
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
TechStem
Membro da: 30/03/2010
440 Reputazione
1 Guida realizzata
Hi there.. I just bought a display for my aspire 5536 and it seems it has a different fitting for the cable.. in fact I bought an LED display and the original one was an LCD (there is an inverter fitted in the lid under the screen) ok.. my question.. Is that possible under any circumstances to fit this new LED screen in my laptop by changing the video cable with a proper one for this new screen??
Law199 - Replica
Hi, thanks for the info. Can you tell me the part number of the LCD screen? thanks.
pandearroz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,171
