Introduzione
Install a new keyboard for an Acer 5100 laptop.
Open and push the screen back all the way until it is horizontal with the rest of the laptop. Locate the panel above the keyboard that has the power button on it.
  • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
  • Locate the panel above the keyboard that has the power button on it.
  • Remove this panel by using a spudger to pry up the sides.
    • You are using the spudger to release tabs holding the panel in place.
  • After you have used the spudger to release the tabs, lift up the panel.
Aggiungi Commento
Under the panel, locate and remove the two screws that connect the keyboard to the laptop. One screw is located above the F5 button, and the other one is located above the F10 button. Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard. Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  • Under the panel, locate and remove the two screws that connect the keyboard to the laptop. One screw is located above the F5 button, and the other one is located above the F10 button.
  • Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
Aggiungi Commento
Release the catch on the ribbon socket, by sliding the two tabs toward the ribbon, then pull the ribbon, which is located under the keyboard, to detach it from the motherboard.
  • Release the catch on the ribbon socket, by sliding the two tabs toward the ribbon, then pull the ribbon, which is located under the keyboard, to detach it from the motherboard.
  • Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
steve foss - Replica
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
Valerio Vischio - Replica
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
Conclusione
Altre 7 persone hanno completato questa guida.
Brad Rollinson
Membro da: 29/09/2010
1.089 Reputazione
8 Guide realizzate
Cal Poly, Team 14-39, Forte Fall 2010 Membro di Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 12,355
