Introduzione
This guide will show you how to remove a hard disk drive and install a new one for a Acer Aspire 5100 laptop.
Place laptop upside down.
  • Place laptop upside down.
  • To get to the hard drive, remove the two screws located on the panel to the right of the battery.
    • Although the battery is missing in this photo, it is not necessary to remove.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Lift up the panel.
  • Lift up the panel.
Aggiungi Commento
Hard disk drive should now be visible. Slide the hard disk drive to the right to disconnect it from the laptop. Lift up and remove the hard disk drive.
  • Hard disk drive should now be visible.
  • Slide the hard disk drive to the right to disconnect it from the laptop.
  • Lift up and remove the hard disk drive.
  • Slide in the new hard disk drive.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Brad Rollinson
Membro da: 29/09/2010
1.089 Reputazione
8 Guide realizzate
Cal Poly, Team 14-39, Forte Fall 2010 Membro di Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 57
Tutti i Tempi: 18,260
