Salta al contenuto principale
Accessing Samsung ML2510 Circuit Board
Cosa ti serve
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: passo 1, immagine 1 di 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: passo 1, immagine 2 di 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: passo 1, immagine 3 di 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: passo 3, immagine 1 di 3 Accessing Samsung ML2510 Circuit Board: passo 3, immagine 2 di 3 Accessing Samsung ML2510 Circuit Board: passo 3, immagine 3 di 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: passo 4, immagine 1 di 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: passo 4, immagine 2 di 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: passo 4, immagine 3 di 3
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: passo 5, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: passo 6, immagine 1 di 3 Accessing Samsung ML2510 Circuit Board: passo 6, immagine 2 di 3 Accessing Samsung ML2510 Circuit Board: passo 6, immagine 3 di 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: passo 7, immagine 1 di 3 Accessing Samsung ML2510 Circuit Board: passo 7, immagine 2 di 3 Accessing Samsung ML2510 Circuit Board: passo 7, immagine 3 di 3
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: passo 8, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: passo 9, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: passo 10, immagine 1 di 2 Accessing Samsung ML2510 Circuit Board: passo 10, immagine 2 di 2
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
Conclusione
Altre 3 persone hanno completato questa guida.
bbaustin
Membro da: 10/12/11
268 Reputazione
6 Guide realizzate
Cal Poly, Team 17-18, Regan Fall 2011 Membro di Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,829
