Introduzione
The Nokia 3100b may not vibrate anymore when the phone is set in Vibrate mode. This guide will show you how to access the vibrating unit.
Parti
Nessuna parte richiesta.
Make sure your phone is turned off.
  • Make sure your phone is turned off.
Aggiungi Commento
Press the button on the back of the phone and slide the back panel off.
  • Press the button on the back of the phone and slide the back panel off.
  • Remove the battery by pulling it from the phone.
Aggiungi Commento
Note the small metal frame that  hold the SIM card into place.
  • Note the small metal frame that hold the SIM card into place.
  • Gently pull back the tab and lift open the frame.
Aggiungi Commento
Retrieve your SIM card.
  • Retrieve your SIM card.
Aggiungi Commento
Separate the front cover from the base of the phone.
  • Separate the front cover from the base of the phone.
  • Set the front cover, as indicated, aside.
Aggiungi Commento
Remove the screws indicated using a T6 Torx screwdriver.
  • Remove the screws indicated using a T6 Torx screwdriver.
  • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
Aggiungi Commento
Separate the screen assembly from the base of the phone.
  • Separate the screen assembly from the base of the phone.
  • Set the screen assembly, as indicated, aside.
Aggiungi Commento
The vibrating unit can now be accessed. Note its location in the phone.
  • The vibrating unit can now be accessed. Note its location in the phone.
Aggiungi Commento
The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
  • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
Aggiungi Commento
The vibrating unit is now removed.
  • The vibrating unit is now removed.
Aggiungi Commento
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,515
