Salta al contenuto principale
Accessing Logicboard
Cosa ti serve
  1. Accessing Logicboard, Front and Back Cover: passo 1, immagine 1 di 2 Accessing Logicboard, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing Logicboard: passo 2, immagine 1 di 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing Logicboard: passo 3, immagine 1 di 2 Accessing Logicboard: passo 3, immagine 2 di 2
    • Carefully pull the back of casing away from the front.
  4. Accessing Logicboard: passo 4, immagine 1 di 3 Accessing Logicboard: passo 4, immagine 2 di 3 Accessing Logicboard: passo 4, immagine 3 di 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing Logicboard: passo 5, immagine 1 di 2 Accessing Logicboard: passo 5, immagine 2 di 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing Logicboard, Logicboard: passo 6, immagine 1 di 2 Accessing Logicboard, Logicboard: passo 6, immagine 2 di 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing Logicboard: passo 7, immagine 1 di 2 Accessing Logicboard: passo 7, immagine 2 di 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
  8. Accessing Logicboard: passo 8, immagine 1 di 1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing Logicboard: passo 9, immagine 1 di 3 Accessing Logicboard: passo 9, immagine 2 di 3 Accessing Logicboard: passo 9, immagine 3 di 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing Logicboard: passo 10, immagine 1 di 1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing Logicboard: passo 11, immagine 1 di 1
    • Open the battery cover.
  12. Accessing Logicboard: passo 12, immagine 1 di 2 Accessing Logicboard: passo 12, immagine 2 di 2
    • Lift the indicated plastic piece off.
  13. Accessing Logicboard: passo 13, immagine 1 di 2 Accessing Logicboard: passo 13, immagine 2 di 2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
  14. Accessing Logicboard: passo 14, immagine 1 di 1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
  15. Accessing Logicboard: passo 15, immagine 1 di 3 Accessing Logicboard: passo 15, immagine 2 di 3 Accessing Logicboard: passo 15, immagine 3 di 3
    • Carefully lift up SD cardholder to reveal logicboard.
Conclusione
Nicole Wong
Membro da: 01/30/11
329 Reputazione
3 Guide realizzate
Cal Poly, Team 4-29, Regan Winter 2011 Membro di Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,380
