Introduzione
If your battery no longer holds a charge or you suspect it might be faulty, use this guide to replace it.
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet. Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
If you have a device with SIM card slot, remove SIM card first.
Hans-Josef Hoffmann - Replica
Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
  • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
Aggiungi Commento
Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
Aggiungi Commento
Remove back panel by pulling away from the remaining device. Remove back panel by pulling away from the remaining device.
  • Remove back panel by pulling away from the remaining device.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel. Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
  • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
Aggiungi Commento
Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip. Remove button component by pulling straight outward from the device. Remove button component by pulling straight outward from the device.
  • Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip.
  • Remove button component by pulling straight outward from the device.
Aggiungi Commento
Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
  • Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
TF101G has a flex print, probably the GSM antenna, glued on top of the metal panel. It is connected to a printed circuit board with a connector similar to that in step 8.
Metal panel is glued to the battery. Remove with care.
  • Metal panel is glued to the battery. Remove with care.
  • Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
Aggiungi Commento
Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
  • Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
Aggiungi Commento
Battery is glued to device. Remove with care. Peel off tape from around the edges of the battery. Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
  • Battery is glued to device. Remove with care.
  • Peel off tape from around the edges of the battery.
  • Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
  • Lift up the battery off of the device.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Sandy Babich
Membro da: 23/09/2014
1.589 Reputazione
5 Guide realizzate
Cal Poly, Team 13-9, Forte Fall 2014 Membro di Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Membri
6 Guide realizzate
Ahhhh, the battery connector sides out right?!? Lifting it up would remove its socket from the board as you can see in the last 3 pics.
Also under the middle of the battery is another strip of tape attached to a thin bar the width (long dimension) of the battery which i could see snapping if you attempted to remove the battery without sliding a tool down between the battery and bar.
lukedw - Replica
Where can I purchase the battery? It wasn't on the parts list on this page.
Is it worth the effort replacing the battery for this old tablet when new ones a re more powerful and less expensive?
Any help is appreciated.
Bob
Bob Miksic - Replica
I followed step 11 and pried the battery connector upward. Ended up severing the socket, ruining my entire tablet. Thanks.
Keith Marchell - Replica
Do not pry up battery connector as described in step 11, connector slides off easily. This I now know from following the instructions and will have to purchase a replacement board if I wish to use this tablet again.
Anthony McC - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 169
Tutti i Tempi: 10,931
