Introduzione
This guide will explain the process of installing a new battery, or replacing an existing one. The ASUS F555UA-EH71 comes with a 14.8V 38Wh Li-ion battery.
Cosa ti serve
Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
Altre 2 persone hanno completato questa guida.
