Introduzione
This guide will show you how to replace the Asus Eee 1018P Hard Drive. The hard drive is one of the most important components of a laptop because this is where all data such as files, pictures, and videos are stored. Primary reasons for replacing hard drives includes hard drive corruption and failure, as well as wanting to upgrade the laptop's storage capacity.
Before proceeding, make sure the laptop is competely shut down so as not to corrupt the system.
Cosa ti serve
Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
Remove the screws securing the bottom case to the keyboard.
Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
Remove the black ribbon cable from the motherboard.
Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
Use a Phillips #0 screwdriver to remove the two 4.52 mm screws securing the hard drive case to the laptop.
Altre 12 persone hanno completato questa guida.
3 Commenti
Any advice on replacing with a SSD drive?
SATA II 3GBs
Would a 6gbs drive be a waste? or even work?
same question for SATA III
