Salta al contenuto principale
ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement
Cosa ti serve
  1. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Lower Case: passo 1, immagine 1 di 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: passo 3, immagine 1 di 1
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: passo 4, immagine 1 di 1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: passo 5, immagine 1 di 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 2 ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: passo 6, immagine 2 di 2
    • Remove the keyboard from the laptop.
    • The Trackpad is attached to the keyboard assembly. The Trackpad replacement guide can be found on the ASUS Chromebook CPPA-RBRKT07 homepage.
Conclusione
Cal Poly, Team S19-G4, White Winter 2019 Membro di Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 446
