Introduzione
This repair guide will walk you through the steps to removing and replacing the internal drive component of your APS Tech 101629 CD-Drive. First the external casing will need to be removed.
Parti
Nessuna parte richiesta.
Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
  • Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
Aggiungi Commento
Unscrew the four screws previously covered by the feet. Unscrew the four screws previously covered by the feet.
  • Unscrew the four screws previously covered by the feet.
Aggiungi Commento
Flip the device right side up, then gently slide the casing upwards and off the hard drive. Flip the device right side up, then gently slide the casing upwards and off the hard drive.
  • Flip the device right side up, then gently slide the casing upwards and off the hard drive.
Aggiungi Commento
Flip device upside down again.
  • Flip device upside down again.
  • Gently pry the bottom gray casing away from the device.
Aggiungi Commento
Rotate so back of device is facing you, then gently pry the back casing away. When back casing is removed, the fan will become loose.
  • Rotate so back of device is facing you, then gently pry the back casing away.
  • When back casing is removed, the fan will become loose.
Aggiungi Commento
Flip so device is upside down. Remove 4 screws with Phillips #1 screw driver.
  • Flip so device is upside down.
  • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
Aggiungi Commento
Slide the internal drive component away from the back of the device. Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
  • Slide the internal drive component away from the back of the device.
  • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Alexis Weckel
Membro da: 11/04/2011
140 Reputazione
3 Guide realizzate
Cal Poly, Team 24-60, Amido Spring 2011 Membro di Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 869
