Salta al contenuto principale
2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement
Cosa ti serve
  1. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, immagine 1 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, immagine 2 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, immagine 3 di 3
    • Here is the FOB for my Jeep. It decided to finally quit. The functionality became less over the last couple of weeks and required frequent attempts to unlock the vehicle etc.
    • Remove the key by moving
    • locking hatch to the left side first.
    • The two halves where the FOB needs to be split are clearly visible
  2. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, immagine 1 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, immagine 2 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, immagine 3 di 3
    • Using a plastic opening tool (or finger nail, guitar pick etc.) start at the front of the FOB to separate it
    • Moving the tool along the split line with slight sideways pressure
    • will separate the FOB easily.
  3. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, immagine 1 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, immagine 2 di 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, immagine 3 di 3
    • Here is the cleanly opened FOB
    • Bottom half of the FOB contains the CR2032 coin battery
    • Remove the battery by pulling it out of the holder pushing it gently against the spring contacts.
    • Replace the battery following the polarity with the positive side to the body of the FOB
  4. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 4, immagine 1 di 2 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 4, immagine 2 di 2
    • Insert wisdom here.
Conclusione
Altre 12 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
783.662 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
550 Guide realizzate
Un commento
Very easy! Thank you!
Cheryl Talley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 92
Ultimi 30 Giorni: 458
Tutti i Tempi: 71,569
