Parti
Nessuna parte richiesta.
Pull the latch by the drivers feet to open the hood.
  • Pull the latch by the drivers feet to open the hood.
Aggiungi Commento
Push the latch under the center of the car's hood.
  • Push the latch under the center of the car's hood.
Aggiungi Commento
Remove all the pins on the front cover to gain access to the back of the grille. Remove all the pins on the front cover to gain access to the back of the grille. Remove all the pins on the front cover to gain access to the back of the grille.
  • Remove all the pins on the front cover to gain access to the back of the grille.
Aggiungi Commento
Push on the pins behind the grill to make the pony emblem come out of the front of the grille. Push on the pins behind the grill to make the pony emblem come out of the front of the grille.
  • Push on the pins behind the grill to make the pony emblem come out of the front of the grille.
For the 2014 Mustang GT, the pins are secured with metal rings. Simply pushing on them will not release the pony emblem. More details are needed to remove them.
Doug - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Christopher Pell
Membro da: 26/09/2012
173 Reputazione
5 Guide realizzate
Cal Poly, Team 15-45, Forte Fall 2012 Membro di Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 54
Tutti i Tempi: 3,984
