Introduzione
This guide will show how to replace a dead or dying battery in a Honda Shadow Spirit motorbike. All tools should be included in the motorbike in the tool box.
NOTE: The directions in the guide refer to the view from the back of the motorbike.
Left = The side opposite the tail pipe
Right = The side with the tail pipe
Parti
Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
Aggiungi Commento
The tool box is located under the panel. Using the key to the motorbike, unlock the tool box. Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  • The tool box is located under the panel.
  • Using the key to the motorbike, unlock the tool box.
  • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
Aggiungi Commento
Using the allen wrench, remove the screws on both sides of the bike seat. Using the allen wrench, remove the screws on both sides of the bike seat.
  • Using the allen wrench, remove the screws on both sides of the bike seat.
Aggiungi Commento
Pull the rear of the seat upwards.
  • Pull the rear of the seat upwards.
  • Pull the seat backwards to remove it from the bike.
Aggiungi Commento
Using the screwdriver, remove the screw holding the plastic cover.
  • Using the screwdriver, remove the screw holding the plastic cover.
Aggiungi Commento
Pull the cover off the battery and remove the fuse box from the cover.
  • Pull the cover off the battery and remove the fuse box from the cover.
  • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
Aggiungi Commento
Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
  • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
  • Place the wire over the left side of the bike.
Aggiungi Commento
Also using the screwdriver, remove the positive (+) cable from the battery.
  • Also using the screwdriver, remove the positive (+) cable from the battery.
  • Place the wire over the right side of the bike.
  • Do not let the red(+) and black(-) wires touch
Aggiungi Commento
Remove the battery from the bike by pulling upwards.
  • Remove the battery from the bike by pulling upwards.
This part of the removal is confusing. My battery seems to be attached to the plastic housing it is in - may even be bolted under the bottom - I can't tell. But it does not just lift out..
Denise - Replica
im having the same issue.
ejb06 -
Same here, just pulling up on the battery does nothing
devanwetherby - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 1-7, Donnelly Fall 2014 Membro di USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Membro
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 91
Ultimi 30 Giorni: 488
Tutti i Tempi: 8,253
