Introduzione
An engine air filter is needed to filter the air flowing into the engine.
Parti
Identify the open hood latch. It is located to the left of your brake pedal. Pull latch toward you. You should hear a click from the front of the car.
  • Identify the open hood latch. It is located to the left of your brake pedal.
  • Pull latch toward you. You should hear a click from the front of the car.
Aggiungi Commento
Walk to the front of the car. Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood. Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  • Walk to the front of the car.
  • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
  • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
Aggiungi Commento
Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
  • Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
Aggiungi Commento
Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
  • Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
  • The bolts cannot be completely removed.
Aggiungi Commento
Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
  • Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up.
  • It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
Aggiungi Commento
Remove the old air filter by gently pulling it from the top of the Air Filter housing. Replace the old air filter with a new one. The blue side should be facing down.
  • Remove the old air filter by gently pulling it from the top of the Air Filter housing.
  • Replace the old air filter with a new one. The blue side should be facing down.
Aggiungi Commento
Conclusione
Matt Ondriezek
Membro da: 14/04/2014
400 Reputazione
3 Guide realizzate
Cal Poly, Team 12-35, Maness Spring 2014 Membro di Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 95
Tutti i Tempi: 1,400
