Salta al contenuto principale
2004 Toyota Sienna Sliding Door Motor Replacement
Cosa ti serve
Panoramica Video
  1. 2004 Toyota Sienna Sliding Door Motor Replacement, Sliding Door Motor: passo 1, immagine 1 di 1
    • First, test both sliding doors to identify the problem with the driver's side door
    • source.
  2. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 2, immagine 1 di 1
    • Remove the second-row seat to access the door panel
    • source.
  3. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 3, immagine 1 di 1
    • Remove the two Phillips screws holding the door panel in place
    • source.
  4. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 4, immagine 1 di 1
    • Carefully remove the door panel by lifting it out and disconnect the power window
    • source.
  5. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 5, immagine 1 di 1
    • Close the door and observe the actuator motor on the working passenger side door for comparison
    • source.
  6. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 6, immagine 1 di 1
    • On the driver's side door, test the voltage to confirm it's an issue with the actuator motor and not an electrical problem
    • source.
  7. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 7, immagine 1 di 1
    • Order a replacement actuator motor (Part #s in the video) and wait for its arrival
    • source.
  8. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 8, immagine 1 di 1
    • Remove the window regulator by lowering the window and accessing the bolts through the portholes
    • source.
  9. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 9, immagine 1 di 1
    • Remove the actuator motor by grinding off the stripped Phillips screws with a Dremel tool or using vice grips
    • source.
  10. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 10, immagine 1 di 1
    • Replace the actuator motor with the new part, using socket screws from wall sockets or light switches if necessary
    • source.
  11. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 11, immagine 1 di 1
    • Reassemble the window regulator and test the window function
    • source.
  12. 2004 Toyota Sienna Sliding Door Motor Replacement: passo 12, immagine 1 di 1
    • Test the sliding door in manual mode and then in power mode
    • source.
Conclusione
eCuration
Membro da: 05/19/17
376.693 Reputazione
235 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
16.562 Guide realizzate
Un commento
Great instructions! I was able to fix sliding door.
However, the window doesn’t scroll up all the way and it wiggles if you pull on it.
What did did I do wrong? Any suggestions are appreciated.
Nara Lim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,159
