Introduzione
It is suggested that the cabin air filter be replaced every 15,000 miles.
Open the passenger side door and locate the glove box. Open and empty the glove box. Open the passenger side door and locate the glove box. Open and empty the glove box.
  • Open the passenger side door and locate the glove box. Open and empty the glove box.
Aggiungi Commento
Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
  • Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
Aggiungi Commento
The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
  • The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
Aggiungi Commento
Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges. Push the tabs inward and gently shake the housing free while pulling straight out. Push the tabs inward and gently shake the housing free while pulling straight out.
  • Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
  • Push the tabs inward and gently shake the housing free while pulling straight out.
Aggiungi Commento
Push the air filter out of the plastic housing from the bottom and discard.
  • Push the air filter out of the plastic housing from the bottom and discard.
Aggiungi Commento
Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy. Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
  • Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
  • Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
  • Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray.
Aggiungi Commento
Conclusione
Altre 15 persone hanno completato questa guida.
Shaun MacDonald
Membro da: 03/10/2012
1.696 Reputazione
17 Guide realizzate
Cal Poly, Team 24-27, Regan Fall 2012 Membro di Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membri
17 Guide realizzate
Is it that hard to say i don,t know instead of line of bs. Thank you shaun, saved me time an aggrevation. Your true car guy bro.
Robert McLaughlin - Replica
What are you taking about? What part of this guide is BS?
David Spalding -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 420
Tutti i Tempi: 19,240
