Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Strumenti
Parti
Nessuna parte richiesta.
Caution! Vehicle must be turned off before attempting this replacement. Touching the battery terminals while the car is running may cause risk of electrocution.
  • Caution! Vehicle must be turned off before attempting this replacement. Touching the battery terminals while the car is running may cause risk of electrocution.
Aggiungi Commento
Remove the connections from both the negative and the positive terminals of the battery
  • Remove the connections from both the negative and the positive terminals of the battery
  • When removing the battery, the negative terminal must be removed first. When re-installing the battery, the positive must be connected first.
When removing the battery, the negative terminal must be removed first. When re-installing the battery, the positive must be done first.
Vin Coniglione - Replica
Using a socket wrench, remove the battery bracket from the top of the battery.
  • Using a socket wrench, remove the battery bracket from the top of the battery.
  • Depending on the condition of the car, the bolts may be rusted, making the removal of them a challenge.
Aggiungi Commento
Ensure that there are no connections remaining on the battery.
  • Ensure that there are no connections remaining on the battery.
  • Lift up the battery and remove it from the battery tray.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 370
Tutti i Tempi: 20,527
