Salta al contenuto principale
1999-2004 Honda Odyssey Trunk Struts Replacement
Cosa ti serve
  1. 1999-2004 Honda Odyssey Trunk Struts Replacement, Trunk Struts: passo 1, immagine 1 di 1
    • IMPORTANT: Make sure to securely prop open the trunk with something sturdy. (if not have someone hold open the trunk)
  2. 1999-2004 Honda Odyssey Trunk Struts Replacement: passo 2, immagine 1 di 1
    • Use a small flat head screwdriver to pry open the clip. Insert the screwdriver head into the smal opening. (this picture shows the clip closed)
  3. 1999-2004 Honda Odyssey Trunk Struts Replacement: passo 3, immagine 1 di 1
    • Once the clip is open, simply pull the strut away from trunk. It might require a little force, but should easily come off. You may have to lift the trunk a little.
  4. 1999-2004 Honda Odyssey Trunk Struts Replacement: passo 4, immagine 1 di 1
    • Repeat for the bottom strut. Open clip and remove strut.
    • Adding the new strut is easy. The strut should just snaps into place. You should hear a click when its on properly. Make sure to wiggle it a little to make sure its on.
    • You may have to lift the trunk to get the strut to fit at both ends.
    • Repeat on other side. I would recommend replacing the struts as a pair.
Conclusione
Altre 2 persone hanno completato questa guida.
pacopike1
Membro da: 09/02/11
155 Reputazione
1 Guida realizzata
Un commento
The replacement tailgate struts from Honda come with a dab of grease in the socket at each end of the strut. Check aftermarket struts for grease and add some yourself if there’s none.
Also, while the old strut is removed, check that the mounting ball bolts are tight. Two of mine were loose.
DaveT - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,035
