Introduzione
This guide will follow up on the removal of the front dash panel removal and show you how to access the actual stereo head unit.
Parti
Nessuna parte richiesta.
Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips.  Be careful on the thin sections below the head unit as to not snap the trim.
  • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
Aggiungi Commento
Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
  • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
Aggiungi Commento
Unscrew the four screws from the sides of the deck, circled here.
  • Unscrew the four screws from the sides of the deck, circled here.
Aggiungi Commento
Pull the head unit straight out gently until the two wire harnesses are exposed.
  • Pull the head unit straight out gently until the two wire harnesses are exposed.
Aggiungi Commento
Push down on the tabs and remove the wiring from their blue and white harnesses.
  • Push down on the tabs and remove the wiring from their blue and white harnesses.
  • These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
  • As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
Hi there, what is the blue harness for?
pankajpreetsingh - Replica
Can you please include instructions for head over speakers
Conclusione
Brayden
Membro da: 05/10/2012
4 Reputazione
5 Guide realizzate
Cal Poly, Team 18-42, Regan Fall 2012 Membro di Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,271
