Firstly Disconnect  battery Always take the negative terminal off first.
  • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Aggiungi Commento
Unlatch the 2 clasps. Loosen screw on metal band.
  • Unlatch the 2 clasps.
  • Loosen screw on metal band.
Aggiungi Commento
Disconnect electronic sensor. Press on the 2 latches, pulling the cable away from sensor.
  • Disconnect electronic sensor.
  • Press on the 2 latches, pulling the cable away from sensor.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Disconnect hose from MAFS. Remove MAFS.
  • Disconnect hose from MAFS.
  • Remove MAFS.
Aggiungi Commento
Steps 4-6 are for cleaning only.
  • Steps 4-6 are for cleaning only.
  • Spray MAFS cleaner along direction of travel, shown by arrow.
Aggiungi Commento
Clean electronic coupling with electronics cleaner. Clean electronic coupling with electronics cleaner.
  • Clean electronic coupling with electronics cleaner.
Aggiungi Commento
Inject conducting lubricant into  MAFS electronic coupling. Inject conducting lubricant into  MAFS electronic coupling.
  • Inject conducting lubricant into MAFS electronic coupling.
Aggiungi Commento
Re attach MAFS to air filter housing and intake hose. Tighten screw on metal band. Latch clasps on either side of MAFS.
  • Re attach MAFS to air filter housing and intake hose.
  • Tighten screw on metal band.
  • Latch clasps on either side of MAFS.
Aggiungi Commento
Re attach electronic cable to MAFS.
  • Re attach electronic cable to MAFS.
Aggiungi Commento
Conclusione
Isaac Nitschke
Membro da: 11/10/2010
61 Reputazione
5 Guide realizzate
Cal Poly, Team 3-28, Regan Fall 2010 Membro di Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 43
Tutti i Tempi: 7,804
