Introduzione
In order to perform several of the repair guides for the Volvo 740, the rear wheels of the car must be raised off the ground. This guide will show you how to do this using a hydraulic car jack and jack stands.
Strumenti
Parti
Nessuna parte richiesta.
Turn car off and remove keys from ignition.
  • Turn car off and remove keys from ignition.
  • Place car in park (automatic) or neutral (manual).
  • Engage parking brake.
Aggiungi Commento
Use hydraulic jack on frame of car to raise car. Place jack head underneath frame couple (pictured).
  • Use hydraulic jack on frame of car to raise car.
  • Place jack head underneath frame couple (pictured).
  • Only necessary to jack the car until the wheels are just off the ground.
Aggiungi Commento
Place jack stand on frame of car and remove jack. Do not work under car supported only by hydraulic jack, serious injury or death may result.
  • Place jack stand on frame of car and remove jack.
  • Do not work under car supported only by hydraulic jack, serious injury or death may result.
Aggiungi Commento
Conclusione
Isaac Nitschke
Membro da: 11/10/2010
61 Reputazione
5 Guide realizzate
Cal Poly, Team 3-28, Regan Fall 2010 Membro di Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,735
