Introduzione
This guide will teach you to remove the keypad from your Nokia 6061 flip phone to make repairs or insert a replacement piece.
Open the phone, so you can see the keyboard.
  • Open the phone, so you can see the keyboard.
  • Use the opening tool to remove the call, send, end button, and plastic keypad covering (use moderate force).
Aggiungi Commento
Use a T6 screwdriver to remove 4-screws (one from each corner of the keypad). Use a T6 screwdriver to remove 4-screws (one from each corner of the keypad). Use a T6 screwdriver to remove 4-screws (one from each corner of the keypad).
  • Use a T6 screwdriver to remove 4-screws (one from each corner of the keypad).
Aggiungi Commento
Carefully lift and remove the keypad.
  • Carefully lift and remove the keypad.
Aggiungi Commento
Conclusione
rosin7
Membro da: 14/02/2013
55 Reputazione
4 Guide realizzate
Ohio State, Team 1-3, Buehl Spring 2013 Membro di Ohio State, Team 1-3, Buehl Spring 2013
OSU-BUEHL-S13S1G3
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 684
